November 11, 2020, 12:06 |
ANSYS Meshing is very slow
roberta
Rep Power: 6 |
Hi everybody!
As I wrote in the title, I'm having some trouble with ANSYS meshing tool, which takes too long for generating mesh. Here's the problem: my geometry is a 2d rapresentation of a pipe with a single hole orifice plate; because of the symmetry I'm simulating only half of the real geometry. To draw the geometry I used the ANSYS geometry tool. For the mesh, I created a body sizing and two different edge sizing with quadrilateral dominant method and I started with "big" element size, which led to have a final number of cells more or less of 82 000. After the simulation with this mesh I decided to refine the grid, making the element size the half of the initial one (both for body and edges sizing) and I noticed that the refinement required more or less one hour for every refining (which I made separately) and at end of the mesh generation I had 250 000 elements. What I saw is that the mesh status was stucked for long time at "converting triangle to quad..." at 70%; when reached 80% the process ended after 5-10 minutes. Now I'm trying to refine again the mesh, by half of the previous size and the process is stucked at "converting triangle to quad..." at 70% since three hours (I'm refining always one sizing at time, so actually I didn't refine nothing at all). I attach an img of the meshing process. I have to say that I have some trouble with internet connection, so sometimes ANSYS displays the error "no license available at this time hh:mm". What could be the problem? Maybe the license not available due the poor internet connection? These are the features of the computer I'm using: -intel(R) Xeon(R) silver 4114 CPU@ 2.20 GHz 2.19 GHz (two processors); -RAM 128 GB (128 GB available); -Windows 10 64 bit. I think this is all, if anything isn't clear or if I missed some important info please let me know. Thank you in advance if you will help me and have a nice day! PS: sorry for my english, I hope that what I wrote is clear enough; if not please let me know! PPS: while I was writing this post the meshing status reached 80%, so you will see that percentage in the img. Last edited by r.d.; November 17, 2020 at 06:48. Reason: forgot info |
[ANSYS Meshing] Mixed Order Meshing in ANSYS Meshing | oozcan | ANSYS Meshing & Geometry | 1 | August 1, 2020 07:48 |
Mesh difference between 14.5 version and 15.0 version in ansys meshing | sunxihui | ANSYS Meshing & Geometry | 0 | May 6, 2014 05:22 |
ANSYS 2D Meshing | The Engineer 2014 | ANSYS Meshing & Geometry | 0 | March 26, 2014 21:54 |
[Other] Ansys Meshing vs Ansys ICEM CFD | JuPa | ANSYS Meshing & Geometry | 5 | September 19, 2012 10:48 |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 06:22 |
