[ICEM] I find that I cannot choose more than two edges to set the line nodes,I can only choo
Old   November 3, 2020, 22:52
Default I find that I cannot choose more than two edges to set the line nodes,I can only choo
hitzhwan is on a distinguished road
I find that I cannot choose more than two edges to set the line nodes,I can only choose one edge to set, who can tell me how to choose more?
hitzhwan is offline   Reply With Quote
Old   November 4, 2020, 03:04
M
AtoHM is on a distinguished road
When doing 'normal' blocking you can select Copy To Parallel Edges. Besides, I have been struggeling with copying the bunching and node number to other edges too, it seems to be either buggy or I am too stupid to use it
AtoHM is offline   Reply With Quote
Old   November 4, 2020, 11:52
Default Thank you.I know the copy the to the parallel edges. But it can not copy to the non-p
Thank you.I know the copy the to the parallel edges. But it can not copy to the non-parallel edges. Do you know how to do that?
Old   November 11, 2020, 01:15
Kira
aero_head is on a distinguished road
Just want to ask for clarity - the block is split in that (non-parallel) direction as well, right? And the edges associated with the lines?
aero_head is offline   Reply With Quote
Old   November 11, 2020, 10:31
Default I mean some edges are not parallel ,how can I set they at a same parameter.
Old   December 27, 2020, 03:25
Kira
Sorry for the delayed reply. Instead of copying 'To All Parallel Edges', there should be an option to copy 'To Selected Edges'. Just click on the edges in question.
Old   December 27, 2020, 12:12
Default Hi, where is the option, could you send me a image?Thank you.
Old   December 27, 2020, 12:34
Kira
Attached are some images. You just select the drop down arrow to the right of where it says 'To All Parallel Edges' to select the option for 'To Selected Edges'.
[Gmsh] Structured meshing in Gmsh the_phew OpenFOAM Meshing & Mesh Conversion 19 August 24, 2022 04:19
does Hyperthreading affect the application of UDF? SJSW Fluent UDF and Scheme Programming 11 October 10, 2018 23:28
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 15:06
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 22:45
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
