[ANSYS Meshing] YPlus for simple pipe flow simulation in CFX
Old   September 7, 2020, 10:06
Default YPlus for simple pipe flow simulation in CFX
Richard
Rischa is on a distinguished road
Hello Guys,
I try to simulate a simple pipe flow with SST in CFX.
My problem is: I want to achieve YPlus around 1, but until now I can't achieve any value below 10, even if I lower the first layer hight about an magnitude.
I calculated the first layer with 9e-06 m and lowered it down to 1e-07 m (tryed higher values too). At this point my solution stops to converge at about 1e-04 (conv. criteria at 1e-06) and the YPlus value stays at 10-12.
I also tryed structured and unstructured meshing with element size of 1 mm.
My tube has a diameter of 0.02 m and a length of 2 m at an Inlet velocity of 2 m/s. I use water at 20 °C. Sand grain roughness is 0.175 mm.
I get this values only if I use the Ansys Post YPlus value. When I calculate it by my self (as expression) with:
y+ = \frac {\sqrt{ \frac{\tau _{wall}}{\rho}}*\Delta n}{\nu}
For \Deltan I used both Wall Distance and my specified first prism layer hight (0.000009 m).
With this I get values about 0.5 to 1.
Is this a well known problem and I am dumb don't knowing it or has anyone an idea what's the problem in this case?
Thanks for your help.
Rischa is offline   Reply With Quote
pipe flow, prism layer meshing, tube flow, y +, y plus
Pressure drop in pipe flow with Large Eddy Simulation xerox FLUENT 1 October 16, 2019 09:55
Simulation of flow through a Pump as turbine by Ansys CFX Aladinos05 CFX 6 June 13, 2017 22:34
Pipe flow simulation problem with pisoFoam: not getting parabolic profile sahmed OpenFOAM Running, Solving & CFD 1 September 7, 2016 15:00
Pipe Flow Simulation comingdaytime OpenFOAM Running, Solving & CFD 3 July 27, 2016 11:40
CFX Coronary Flow Simulation ld1305 CFX 13 February 7, 2012 04:17
