[ANSYS Meshing] High skewness cells on small edges
Old   September 1, 2020, 14:05
Default High skewness cells on small edges
Ali Muslim Abdulmohsin Tukkee
Ali Tukkee is on a distinguished road
I'm modelling a vortex generator using ANSYS Fluent 16.2 and trying to generate my mesh with ANSYS ICEM. I've created my geometry with Autocad and my problem is that the geometry contains small edges at which highly skewed cells are generated, I've tried to refine my mesh and also tried edge sizing but there are always some cells with a skewness of 0.99 that causes divergence in the solution. Finally, I tried to separate these cells in Fluent then deactivate them but it did not work maybe because my geometry is one big fluid zone or maybe because these cells are essential to the solver since they are at the entry slots and vanes.
I've attached pictures of the geometry and mesh and to clarify, the entry slots are very narrow edges added to the geometry and the vanes are very narrow curves subtracted from the geometry.
My questions are: how to solve this high skewness cells issue? And if possible is there a better way to make the entries and vanes than the one I used to avoid the problem from the beginning.
Please I appreciate any help or advice to solve this issue.
Ali Tukkee is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 02:37
[snappyHexMesh] SHM Layer Addition Phase dickcruz OpenFOAM Meshing & Mesh Conversion 4 November 1, 2018 08:05
[snappyHexMesh] snappyHexMesh Segmentation Fault avd28 OpenFOAM Meshing & Mesh Conversion 11 May 11, 2015 21:32
[snappyHexMesh] problems using snappyHexMesh 2.1.0 on a supercomputer Sunxing OpenFOAM Meshing & Mesh Conversion 9 September 20, 2014 10:30
[ICEM] error analysis despaired student ANSYS Meshing & Geometry 7 June 27, 2012 12:57
