[ANSYS Meshing] The mesh file exporter failed during translation
Old   August 8, 2020, 11:50
Default The mesh file exporter failed during translation
Gabriela
gabies is on a distinguished road
I have a problem with meshing, but I suppose it's because of geometry and I don't know how to solve it.
I work on a simulation of the airflow over the wing. I prepared the element in Solidworks and moved it to Ansys. Then I created a surface body from it and added enclosure. Together I got 5 parts in simulation, so I supressed irrelevant bodies.
I moved to meshing and when I finished I got a message from the title: 'The mesh file exporter failed during translation'. Then I unsupressed other bodies, but then I got: 'The mesh file exporter could not resolve cyclic denpendencies in overlapping contact regions.Please try to Repair Overlapping Contact Regions.' I tried deleting contacts, hiding unwanted bodies, but it didn't work.
I guess the perfect solution would be "deleting" redundant geometry, however it's not possible from what I know.
Thank you in andvance for any help.
gabies is offline   Reply With Quote
Old   August 9, 2020, 05:21
M
AtoHM is on a distinguished road
Sounds like your geometry is not clean or what you want (already contains irrelevant bodies) and things go wrong from there. I have very limited experience with ANSYS Meshing, but I know Solidworks very well. Maybe you can show an image of your model including the model tree?
AtoHM is offline   Reply With Quote
Old   August 9, 2020, 12:33
Gabriela
Thank you AtoHM for your reply.
I solved my problem-I created surface body in SpaceClaim instead of DesignModeler and supressed connections.
geometry ansys, meshing 3d
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
