[DesignModeler] How to model spring element in ansys aqwa???
Old   August 1, 2020, 13:49
Exclamation How to model spring element in ansys aqwa???
NasrulHassan
nsrlnaim900 is on a distinguished road
I need help on how to model a spring element in ANSYS Design Modeler and ANSYS AQWA. Im need to perform a splash zone analysis of vessel lifting a subsea module into sea water. Can I know how do i model a spring element to imitate the behaviour of Heave Compensator in AQWA? I saw a post from a company called safelink which perform the splash zone crossing using AQWA with a heave compensator. Basically the HC need to be modeled so that it can counter the force in Z director to ensure the sling doesn't slack or become too tension. Appreciate if someone can give me the answer to this problem.
Here I attached the link for your references
http://www.youtube.com/watch?v=d_ZvCZwyZPg
nsrlnaim900 is offline   Reply With Quote
ansys aqwa
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM Ancioi OpenFOAM Meshing & Mesh Conversion 17 January 9, 2019 00:50
2-way FSI in Ansys CFX 15 LucasGasparino CFX 3 August 6, 2015 04:17
Ansys Aqwa services needed irfan ANSYS 0 May 21, 2013 02:30
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Limitation of 2D and 3D model element number Soon CFX 3 January 30, 2006 16:15
