[ANSYS Meshing] Complex Propeller Geometry. Done Yet Undone.
Old   July 25, 2020, 21:28
Default Complex Propeller Geometry. Done Yet Undone.
aunmhd is on a distinguished road
Dear Meshing Community,
It has taken me a considerable amount of time to complete a hex mesh for fairly complex geometry of a propeller. Upon completion, certain quality metrics I achieved are: Quality: 0.3 and Min Angle: 18. An image of the mesh is also attached below.
However, it is unfortunate that the mesh still seems to have problems that I am unable to fathom. I am running CFD simulations with identical BC's and the difference in results I am getting is remarkable: STAR CCM calculates a thrust of 90 N while CFX calculates the same as 57000 N. Fluent says:
"The mesh contains high aspect ratio quadrilateral, polyhedral or hexahedral cells. The default algorithm used to compute the wall distance required by the turbulence models might produce wrong results in these cells..."
Is Fluent harsh on prism cells?
How can I salvage this? Thanks.
aunmhd is offline   Reply With Quote
fluent 12.0, icem 14.0
[ICEM] Holes in complex ICEM geometry alecbann ANSYS Meshing & Geometry 2 April 4, 2019 04:40
Solving complex geometry with compressible flow gfoam FLUENT 1 May 19, 2017 15:56
[ANSYS Meshing] Problem with meshing a complex Geometry (Hex) fluent_beiyo ANSYS Meshing & Geometry 8 April 26, 2014 05:55
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 12, 2012 00:18
plane cutting complex geometry in the middle Lilly FLUENT 0 July 27, 2011 10:01
