[Other] Fixed supports in ANSYS static structural
Old   June 28, 2020, 05:35
Default Fixed supports in ANSYS static structural
HS
amsys is on a distinguished road
I want to run a static structural simulation in ANSYS. My aim is investigate the stress induced on a geometry as a result of a certain pressure being applied. I am using the attached geometry (I will extrude it slightly first to make it 3D). I will apply a pressure BC (I have highlighted where with the black arrow). My question is where would be the best place to add fixed supports on the geometry?
Thanks.
File Type: jpg ECE7A2AD-35A4-4097-ACBB-B4669A0761C7.jpg (63.9 KB, 7 views)
amsys is offline   Reply With Quote
Old   June 30, 2020, 10:00
Erik
evcelica is on a distinguished road
Is the internal pressure uniform?
If so there will be zero net force on the geometry. I would just constrain a single node or vertex anywhere. displacement = 0.
evcelica is offline   Reply With Quote
ansys, boundary condition, static structural
1 way and 2 way FSI in ANSYS Workbench with Fluent and ANSYS Structural jwillie2000 FLUENT 6 November 27, 2017 00:21
How to combine ANSYS Fluent and Structural analysis? diwakar ANSYS 2 June 18, 2015 13:07
Transfer from CFX to Static Structural student82 CFX 1 March 2, 2011 05:17
[DesignModeler] Static Ansys (Ansys) Malyahya ANSYS Meshing & Geometry 2 February 5, 2011 19:25
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 06:08
