[ANSYS Meshing] Generating Mesh on HPC
Old   June 10, 2020, 06:58
Default Generating Mesh on HPC
Ciaran Parker
CiaranStubbsParker is on a distinguished road
Hi there,
I have been running an experiment using a HPC, Linux cluster, and I'm struggling with the meshing part. Due to the complexity of the mesh, I can't run it on the login node, and need to submit it as a job script to a separate node, but I am unsure how. I have set all the necessary sizing and other properties for the mesh, I just need to generate it on one of the computing nodes. I have read on other posts on this forum that it may require a java script, instead of a Python which is used for Fluent job scripts, but I am unsure. Operating a HPC / using Linux is new grounds to me, so any help on the matter would be greatly appreciated.
Kind regards,
Ciaran.
CiaranStubbsParker is offline   Reply With Quote
hpc, job script, meshing
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 06:02
[mesh manipulation] Generating a single cell mesh using a patch of a 3d mesh kebsiali OpenFOAM Meshing & Mesh Conversion 3 May 30, 2016 07:36
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
