[ICEM] Create Solid part mesh (block) indside Fluid part mesh (block)
Old   June 9, 2020, 10:42
Default Create Solid part mesh (block) indside Fluid part mesh (block)
CFDger is on a distinguished road
I want to mesh an object (solid) inside an hypersonic airflow (fluid) in ICEM CFD (2D). I tried several options to generate two separate meshes (one for the solid object) and one for the surrounding air (fluid) which is bounded by the farfield.
I couldn't find an helpful answer to this problem in any forum. I would be very helpful if somebody could help me find the solution for this problem.
Thank you very much.
CFDger is offline   Reply With Quote
Old   June 10, 2020, 04:06
To add some information:
I am interested in the heat transfer in my solid body and its surface temperature (as they are critical during hypersonic flight conditions).
I am currently trying to create an ICEM file for the fluid mesh and an other ICEM file for the solid mesh. Then I will load them both into the Ansys Fluent solver and assign them their values there.
With this method I believe it can get rather hard to match the grid resolution at the contact areas of the solid and fluid.
I hope somebody has experience with this.
Thanks
ansys, blocking, compressible air, icem, mesh
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 06:07
[snappyHexMesh] SnappyHexMesh: How to cut a nozzle out of a solid block, and mesh both MarcusNHofer OpenFOAM Meshing & Mesh Conversion 0 April 6, 2015 11:45
[DesignModeler] How to create fluid body as I first designed the solid part through solid works? rasekh64 ANSYS Meshing & Geometry 9 May 13, 2013 14:15
Differences between solid/ fluid mesh Vidya Raja FLUENT 0 March 14, 2006 18:49
