[ANSYS Meshing] Block-meshing and inflation with complex intersecting wall boundaries |
May 28, 2020, 17:27 |
Andrea Di Ronco
Rep Power: 10 |
Hello everyone!
I'm trying to mesh the attached geometry (Fig. 1). fig1.jpg Basically the geometry features a 1/16 cyclic symmetry, such that the bodies to be actually meshed are only the ones in Fig. 2, where the green-highlighted boundary faces (and the corresponding ones behind) are symmetric.All the other boundary faces are external and therefore treated as walls. fig2.png As you can see, I divided the part into different bodies to try to exploit further symmetries and the capabilities of the MultiZone method. Everything just fine so far, and I'm able to get good quality meshes with approx. 100-200k elements. Selective body meshing and sweepable bodies work like a charm (Fig. 3). fig3.png I use the mesh for some custom multiphysics calculations with OpenFOAM. Results are pretty good in terms of stability and convergence, but I'd like to add some inflation on external boundaries to enforce a better turbulence boundary layer treatment without a dramatic increase of mesh size. When I try to apply inflation on all the external boundaries, the MultiZone method works no more, due to the complex intersection pattern of inflated faces of different bodies (on the egdes highlighted in Fig. 4). fig4.png The only feasibile workaround I found so far is to mesh all bodies with MultiZone, except two which are meshed with Automatic/Tetrahedrons. The resulting meshes (Fig. 5) gives no error (except a warning on stair-step inflation layers, which is reasonably expected due to the particular geometry). Unfortunately, the quality is significantly poorer (in the tet-meshed bodies, of course) and I'm not able to properly simulate to convergence the model. I've also tried the CutCell method, but the overall quality is poor. fig5.png I've been struggling with this for days. Does anyone have some advice for tackling the problem? Some possible alternatives I thought of are:
Perhaps some smart further splitting of the geometry, or maybe some other tool in ANSYS Meshing to add inflation while keeping the structure of the original mesh using MultiZone? Any contribution will be much appreciated! Thank you in advance, Andrea Last edited by Diro7; June 1, 2020 at 11:39. Reason: Correct mesh sizes |
June 1, 2020, 11:17 |
M
Rep Power: 13 |
Hi, since nobody else wrote anything yet, I give you some feedback. Firstly, props for getting that kind of mesh from the multizone method, I never came so far with it.
Secondly, I wonder if it is possible to mesh this all with one blocking approach nevertheless. I would go with 4x3 blocks for a start, create an ogrid for the inner block and one at the outer "ring". Then, the innermost block can be deleted. Then the blocking can be adjusted to fit your ring properly. The parts standing out of the plane can be just added with the insert block tools. The part where the edges converge for the "center" is a bit trickier, but manageable by collapsing a block edge to get a triangular block (viewn from above). Then the only thing left would be to increase the refinement level in the blocks further away from the symmetry axis and finally resolve refinements after creating the mesh. There might be some obstacle I have overlooked, but this might work. Good luck. |
June 2, 2020, 07:03 |
Andrea Di Ronco
Rep Power: 10 |
Hi M!
first of all, thank you for the reply and the valuable suggestions. I'm trying to figure out the precise meaning of what you suggested and how to apply it to my case. I'm no meshing expert and, for instance, I've never heard of such thing as "o-grid" before (my bad, actually). Though after a quick search I realized what you are referring to and that I simply didn't know it had a name of its own Anyway, I'm afraid you may be talking about some kind of meshing functionalities (o-grids, blocking etc) which are not available in ANSYS Meshing, or at least not in the v19 Student version I'm using. Unfortunately my institution doesn't provide full license for PhD students, and it seems for instance that ICEM is not included in Student licenses. Am I correct, or am I just ignoring some functionalities of ANSYS Meshing? Andrea |
June 2, 2020, 13:22 |
M
Rep Power: 13 |
Uh, my bad ... I was talking about ICEM actually, sorry I just now see you tagged it with ANSYS Meshing. Are you sure you cannot access it? We are using ICEM at my company and have ANSYS Meshing available as well, but I do not know if that works vice-versa as well.
June 4, 2020, 05:39 |
Andrea Di Ronco
Rep Power: 10 |
Don't worry! I'll try to figure out if I can somehow access some fully licensed version of ANSYS.
Or I'll try to make use of your comments with alternative meshing tools. Thank you for the help! Best, Andrea |
inflation, multizone |
[ICEM] Hexa Meshing Inflation Problem | avinashcfd | ANSYS Meshing & Geometry | 1 | June 13, 2018 11:56 |
[ANSYS Meshing] Can fine mesh near wall substitute for inflation layers? | evevev | ANSYS Meshing & Geometry | 3 | January 4, 2018 18:59 |
Mapped face meshing confliction with inflation on multizone | nashim.chowdhury | FLUENT | 0 | April 18, 2017 22:56 |
Meshing Help for turbulent flow of a complex 3d geometry!!! | aabir | ANSYS Meshing & Geometry | 6 | June 14, 2016 20:46 |
[ICEM] Troubleshooting Wall Inflation Issue for a 2D Nozzle | cfmontes | ANSYS Meshing & Geometry | 1 | May 14, 2015 19:13 |
