[ICEM] Multiblock Mesh Ogrid Problem
Old   May 13, 2020, 12:48
Default Multiblock Mesh Ogrid Problem
Ruhinsan
soullantern is on a distinguished road
Hi guys
I've meshing a train using ICEM for a while. I've been using octree->delete volume mesh-> create delauney dand prism method for a while, but i think the cell count and meshing time is taking too long.
I tried to create multiblock fill from convert 2D to 3D block, which successfully generated delaunay meshing around the object, but when i tried to create o grid for inflation layer icem cannot create 3D mesh.
I found some surfaces are not properly covered with surface mesh. Does anyone know how to fix this problem?
soullantern is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 13:38
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 18:16
[ICEM] ICEM Structured Mesh Problem OMJT ANSYS Meshing & Geometry 3 March 22, 2013 11:06
