May 10, 2020, 05:38 |
Problem running mesh on fluent
Anas Nur Fauzan
Rep Power: 7 |
Hello.
I'm learning how to generate a mesh with ICEM CFD. I'm using NACA 2412 as my geometry to study it's aerodynamics characteristics. I followed some random meshing tutorial on youtube. However, when I ran it in fluent, I keep getting bad results with warnings such as : 1. Turbulent viscosity limited to viscosity ratio of 1.000000e+05 in xxx cells 2. Reversed flow in xxx face of outflow xx I've done some browsing and this could be caused by bad mesh quality. But in ICEM, it shows quite good quality mesh. I also checked other quality parameters such as skewness and orthogonalities, but I don't really understand how it represents the mesh quality. Is there any way I can improve my mesh quality in ICEM? Thanks in advance, Best Regards. nacaMesh.jpg nacaMaxOrtho.JPG nacaMinOrtho.JPGnacaSkew.JPG |
May 10, 2020, 12:44 |
Gert-Jan
Rep Power: 28 |
These messages have nothing to do with the mesh. Mesh is fine. Looks pretty good.
Reversed flow on the outlet means that the outlet is too close to the object. Just extend your geometry............ |
May 11, 2020, 00:21 |
Anas Nur Fauzan
Rep Power: 7 |
Thank you sir for the reply.
Actually, I have tried to expand the domain behind the airfoil to 30c but still get the reversed flow problem and also this turbulent viscosity ratio problem. When I ran it in Fluent, the continuity and residuals were actually really good. Below 1e-5. However, the results (Cl, Cd, Cm) were bad. I use BC as follows : 1. The top, bottom, and arc edge as inlet BC which I defined with viscosity intensity and hydraulic diameter and velocity of 11 m/s. 2. The straight vertical edge as outflow BC. Am I missing something in defining the BCs? Thanks, Best regards. |
May 11, 2020, 16:44 |
Gert-Jan
Rep Power: 28 |
I don't know. I refuse to use Fluent. I always use CFX.
Therefore I would ask the Fluent forum. |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
Problem About Running Fluent In Linux | mitra | FLUENT | 18 | June 20, 2019 03:11 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
