May 7, 2020, 07:51 |
Base point not defined
Rep Power: 6 |
I'm using ‘Base point and Delta’ ,and sometimes it shows"Base point not defined",but it does not affect normal operation,I just wonder why and maybe it affects something else I don't know
May 7, 2020, 08:20 |
Gert-Jan
Rep Power: 28 |
If you did not select a Base point as reference for the delta's, then probably it positions the new point with a delta from the origin (0,0,0)
May 7, 2020, 21:27 |
Rep Power: 6 |
operating conditions |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 12:38 |
error while running simpleFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 9 | July 14, 2016 06:37 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Plot temperature vs time for a defined point | FREDERIK | FLUENT | 0 | August 26, 2005 05:49 |
