[ANSYS Meshing] Update interfaces
Old   April 29, 2020, 05:13
Default Update interfaces
Cla
Claudia
Cla is on a distinguished road
I'm using Ansys Fluent to study Wankel engine.
Good evening, I have a problem about interfaces, In geometry I have created a Wankel engine with two objects ( engine chamber and inlet/outlet pipes) and their interfaces.I was obliged to create two bodies (chamber and pipes) because only on the red lines the node grid udf is applied. For reducing the time calculation, I have written an udf to let the grid housing move. The problem occurs because the interfaceses move with housing and there isn't an update. I'd like the interface remains fixed in the space while the nodes can rotate and uptate their position as housing. Is it possibile ? Is there another solution?
Yellow lines in files are interfaces and the red lines
Thanks.
Cla is offline   Reply With Quote
Change "Implicit Mesh Update Interval" using UDF ASimonsen Fluent UDF and Scheme Programming 2 October 12, 2017 10:38
Discontinuity across interfaces Nurzhan CFX 2 March 11, 2015 02:59
What type is defined as the interfaces between stator and stator on OF-2.1.1? renyun0511 OpenFOAM Running, Solving & CFD 3 May 18, 2013 09:11
Subdomain or Interfaces (CHT) sandeep_tu CFX 8 July 14, 2009 12:06
grid interfaces kiko FLUENT 0 February 13, 2007 11:28
