[Workbench] Regarding VG geometry upstream of a slope |
April 17, 2020, 06:45 |
Mominul MuKuT
Rep Power: 17 |
Hello all,
Greetings. I have been trying to model flow domain having slope at downstream in which the influence of VGs on flow separation would be investigated. I have used ansys workbench spaceClaim feature to create the flow domain with VGs which are attached here. I have founds few tutorials but confused. Some tutorials subtract VG geometry from domain and remove the geometry (fig.22) and in few tutorials after subtracting the VG geometry they kept the VG geometry (fig.23). I have tried both. But which one is actually correct or good for proper result? In the 2nd case i.e. domain with separate VG geometry, after meshing by ansys, inflation layers squeegeed near VG area. What to do? Thanks in advance. Code:
fig.22 Code:
fig.23 Code:
fig.24 |
ansys, meshing and geometry, spaceclaim, vortex generator |
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE | mariachi | ANSYS Meshing & Geometry | 5 | May 30, 2018 03:52 |
Question about Geometry vs. Meshes | EphemeralMemory | ANSYS Meshing & Geometry | 2 | December 8, 2016 14:02 |
How to scale and translate the grid of particle data and STL geometry | Saidul | Tecplot | 1 | January 11, 2015 22:15 |
Running CFD parallel. There is no geometry file! | CrashLaker | SU2 | 6 | April 10, 2014 04:08 |
[CAD formats] translating geometry from Abaqus to OpenFOAM | skuznet | OpenFOAM Meshing & Mesh Conversion | 3 | January 10, 2014 14:49 |
