[DesignModeler] Face split problem
Old   March 27, 2020, 07:59
Default Face split problem
Clément
solmyr999 is on a distinguished road
Hello everyone, first time posting on this forum,
I have been tasked to make a simulation using ansys as part of my internship, but I've never used the software before and only started using and learning by myself several days ago. Nobody in my lab can actually help me so I decided to seek help here.
Here is my problem : I want to delimit a circle surface on a bigger rectangular face (see attached picture).
I've created a plane from the face and created a circle sketch on it.
I've then tried using the face split function, but I can't use the circle as the tool geometry. My guess is that face split must completely separate the face into two different faces, and cannot "create holes" in faces for topological reasons.
I am therefore stuck and need your help to solve this issue.
Thank you in advance for your time and answers.
solmyr999 is offline   Reply With Quote
Old   March 27, 2020, 08:03
Clément
I don't know if the attached file can be viewed so here is a link to it : https://imgur.com/gK8LYsNhttps://imgur.com/gK8LYsNhttps://imgur.com/gK8LYsNhttps://imgur.com/gK8LYsNhttps://imgur.com/gK8LYsN
Old   March 28, 2020, 04:19
Gert-Jan
Gert-Jan will become famous soon enough
Don't use external links. I'm not going to click on unknown links.
Only post images on the forum.
Gert-Jan is offline   Reply With Quote
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
[Commercial meshers] Face ordering problem for nonrectangular cyclic boundary conditions cfdmarkus OpenFOAM Meshing & Mesh Conversion 3 August 17, 2011 16:07
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
[Commercial meshers] Converting meshes that includes interfaces ham OpenFOAM Meshing & Mesh Conversion 29 January 8, 2007 09:58
