March 20, 2020, 05:31 |
Correct Meshing Strategy
James Adams
Rep Power: 6 |
Hi Folks,
I'm a little stuck with my current mesh. Its got a complicated geometry and I was wondering if anyone has any advice on how I could improve the meshing. I have ran it on a rotational Re of 1e7 and it does not converge. After many meshing changes, I still could not get it to converge. I have tried reducing the Rotational Re to 1e6 and it just about works, but I need tohave it at 1e7. Let me know what you think. |
March 21, 2020, 12:07 |
M
Rep Power: 13 |
In the images I cant see a complex geometry at all. Is that just a cut view?
Your cells are very flat and the grow ratio away from the refined region seems to be quite big. Can you not just avoid the huge elements and add more cells along the edges? The refined regions seem ok and the blocking looks fine from what I can see. |
[snappyHexMesh] snappyHexMesh - 3D Wing Meshing Setup & Trials | denbjornen | OpenFOAM Meshing & Mesh Conversion | 1 | May 25, 2020 12:14 |
[ANSYS Meshing] only automatic meshing works, | kazra | ANSYS Meshing & Geometry | 2 | February 23, 2017 12:38 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
[ICEM] 3D Meshing strategy : a bay | Magicano | ANSYS Meshing & Geometry | 0 | January 3, 2013 20:02 |
Which trailing edge is correct for meshing of aerofoils for CFX | LSC | CFX | 0 | May 10, 2009 13:45 |
