[ANSYS Meshing] Use solid body of influence while suppressing mesh |
March 1, 2020, 22:53 |
Brian Troyer
I am a new user of Ansys CFX version 20.* I would like to simulate a flow around a solid.* I am not interested in wasting mesh on the solid itself, but I would like to use the solid to influence the mesh in the surrounding fluid domain (through body of influence or sphere of influence, etc.).* This strikes me as something which should be simple, but I have not yet found the answer.
* Another possibility, can I affect the mesh of the surrounding fluid domain by face meshing the solid, without meshing the interior of the solid? Thanks, and sorry for such a newbie question! |
March 2, 2020, 03:16 |
M
Rep Power: 13 |
You can either refine a curve, surface or volume depending on what you want to achieve. I think all that should be well covered in tutorials by ANSYS and other resources (youtube, ...). Did you have a look at these?
Like that? https://www.youtube.com/watch?v=QVfJiydCu2g |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[solids4Foam] How to calculate drag coeff when using solids4Foam | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 15 | November 7, 2019 13:50 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 04:19 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
Re-meshing a deformable solid body in a fluid | brashear | CFX | 6 | December 12, 2011 12:13 |
