[ANSYS Meshing] how to generate node at specific location after meshing |
Stanley
Rep Power: 0 ![]() |
I want to apply a force at the center of a cylinder that generated by CYLIND command and I hope there is a node at the center after meshing but there is not.So what I can do to define a node in this location and make it be one of the element node after meshing.I tried to generate the cylinder by define a circle in mid height and extrude it in both positive and negative direction and the center of the circle is generated by the intersection of two diameter lines.But there is still no such a node I can use to apply load.
Stuart
Rep Power: 26 ![]() |
Either split up the geometry to make a vertex or use Virtual Topology to place a virtual vertex where you want the node to be. Then use a patch conforming method to make a node at the free vertex.
ansys, apdl, mesh, node |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Evaluating expression at a specific location in CFX Pre | gotang | CFX | 4 | August 17, 2017 10:33 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 02:54 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
