[ANSYS Meshing] Defining a cell zone in ANSYS meshing for fluent
Old   February 10, 2020, 23:41
Default Defining a cell zone in ANSYS meshing for fluent
Stephen Waite
Stephen Waite is on a distinguished road
Hi there,
As the title says, I am trying to define a cell zone in ANSYS meshing from a subset of the mesh.
The point of this is that in fluent I have wall motion, and I need to perform remeshing. The issue I am facing is that I have areas of local refinement within the domain, and so I need to specify different size criteria otherwise; A) the course regions will re-mesh to a tighter mesh in the first time step and the mesh size will blow up, or B) the refined mesh zone will un-refine itself as the simulation progresses.
Fluent can allow you to specify different re-mesh criteria for separate cell zones, but I am having trouble defining the cell zone.
The local refinement performed in ANSYS meshing is done using a body of influence, and I feel like there should be a way to use that same body to define the cell set/zone. But I cant find it.
Can anyone shed some light on how to define a cell zone, either within ANSYS meshing or with fluent?
Cheers
Stephen
Stephen Waite is offline   Reply With Quote
Old   July 4, 2022, 10:21
Default Defining cell zones in fluent mesher
Sto
Sto is on a distinguished road
I am having a similar problem. Does anyone have an idea how to solve it?
Sto is offline   Reply With Quote
ansys meshing., cell zones, fluent, remeshing
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
[Other] cgnsToFoam problems with "QUAD_4" cells lentschi OpenFOAM Meshing & Mesh Conversion 1 March 9, 2011 05:49
Sliding mesh error Karl Kevala FLUENT 4 February 21, 2001 16:52
