Design Modeler - Create->Body Transformation->Rotate with JS code |
February 6, 2020, 10:49 |
Tim Crimson
Rep Power: 6 |
Hello
Does anyone know how to rotate a body in Design Modeler through JS code If you know, and you can post an example that works, that would make me super happy. Here is my code ///////////////////////////////START//////////////////////////////////////////// ag.gui.NewFile() ag.m.ClearAllErrors() //ag.m.NewSession (true) ag.gui.setUnits(ag.c.UnitMillimeter, ag.c.UnitDegree, ag.c.No) //================================================== ================================================== _elev = -12600.0 _D = 8000.0 // Cable Hole(s) _elev = -12600 //mm _diam = 380 //mm _vert_angle = 45 //deg p=new Object() p.Plane = agb.GetActivePlane() p.Origin = p.Plane.GetOrigin() p.XAxis = p.Plane.GetXAxis() p.YAxis = p.Plane.GetYAxis() p.Sk2 = p.Plane.newSketch() p.Sk2.Name = "Sketch2" //Edges with (p.Sk2) { with (p.Plane) _vert_angle_rad=Math.PI*_vert_angle/180 p.Cr = Circle(0, _elev, _diam/2) } // p.Plane.EvalDimCons() //Final evaluate of all dimensions and constraints in plane agb.Regen() //To insure model validity var Ext1 = agb.Extrude(agc.Add, p.Sk2, agc.DirNormal, agc.ExtentFixed, _D, agc.ExtentFixed, 0.0, agc.No, 0.0, 0.0) agb.Regen() //To insure model validity p=new Object() p.Plane = agb.GetActivePlane() p.Origin = p.Plane.GetOrigin() p.XAxis = p.Plane.GetXAxis() p.YAxis = p.Plane.GetYAxis() p.Sk3 = p.Plane.newSketch() p.Sk3.Name = "Sketch3" //Edges with (p.Sk3) { with (p.Plane) // Sketch rotation line # I want to rotate the newly created extruded body with respect to this line # p.Ln = Line(0, _elev, -_D, _elev) } ////////////////////////////////END///////////////////////////////////////////// So, I would like to rotate the newly created extruded body with respect to the line that I create at the end, 45 deg Any idea? |
body transformation, design modeler, jscript, rotate, rotate body |
[DesignModeler] Design Modeler GUI action script | Enginetix | ANSYS Meshing & Geometry | 0 | September 28, 2018 15:12 |
[DesignModeler] how to use design modeler api to create 3D path for extrude sweep? | efirvida | ANSYS Meshing & Geometry | 9 | May 20, 2015 19:25 |
define a parameter in cfx pre and use it in design modeler | OmidOmid | CFX | 3 | December 3, 2014 09:09 |
Design Modeler not working | tan v | ANSYS | 0 | July 7, 2011 02:43 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
