[ICEM] Make elements respect/follow curves on surface |
January 22, 2020, 06:35 |
Neelay Doshi
Rep Power: 7 |
Hi everyone,
I have a simple cuboidal geometry which has 'Y' shaped curves on 4 surfaces (image-1, 2). I wish to create a structured mesh such that it captures the 'Y' shape on the surface. I have tired to creat a simple mesh (image-3) but the elements become extremely skewed. I even tried to create a degenerate block with its vertices at the 'V' section of 'Y' and then resolve it with a 'y-grid' within but the 2 degenerate blocks being perpendicular to eachother form a prymid at the centre which I don't think can be resolved by structured mesh. Kindly guide me through the procedure of creating a bettre mesh. Thank you ! |
January 23, 2020, 05:19 |
Gert-Jan
Rep Power: 28 |
Your Y-geometry has 3 angles of around 120°. You can't do better than that. If you want a more orthogonal mesh, you need to change your geometry.
January 23, 2020, 08:41 |
#3 | |
Neelay Doshi
Rep Power: 7 |
I have made a very primitive mesh, I haven't used 0-grid, Y-grid etc in the mesh picture I have posted. I cannot change the geometry, but could any of the advance meshing techniques mentioned above help capture the geometry? (as mentioned in the post, I tried using Y-grid but it failed) |
January 23, 2020, 08:54 |
Gert-Jan
Rep Power: 28 |
In your geometry, the elements can't get skewed more than your geometry.
If you apply a fancy blocking (whish is possible) then on average the skewness will improve, but the nasty angles of 60 in the corners will remain. So this won't help. What is the goal of your calculation? Is is flow or mechanical? |
January 23, 2020, 09:05 |
#5 | |
Neelay Doshi
Rep Power: 7 |
It is flow |
January 23, 2020, 09:30 |
Gert-Jan
Rep Power: 28 |
CFX is happy to handle these elements. No doubt about that.
Fluent probably as well, but it is less forgiven. |
curve fit, icem 16.2, structured hex mesh |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 12:05 |
How to make periodic two faces of identical surface and different mesh | dmaz | ANSYS | 1 | September 7, 2015 17:08 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
To make sure nodes on surface | Twiti | CFX | 0 | December 23, 2004 21:06 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
