January 13, 2020, 12:12 |
Different prism meshing parameters
Raditya Wiranegara
Rep Power: 17 |
Dear All,
I wonder if it is possible to generate prism layers with different 'Prism Meshing Parameter' on different walls in ICEM. The idea here is to adjust the 'Initial Height' of the layer to the flow parameters of the core flow in adjacent to each wall accordingly, hence keeping y+ similar on all walls whilst the freestream velocity varies. Has anyone ever done this? Many thanks. |
January 14, 2020, 05:42 |
Gert-Jan
Rep Power: 28 |
Yes, this is possible. In the meshing tab, the second Icon gives you a table with all named walls. In this table, you can set anything you like to get any prisms layer you can imagine. Look in the help for the correct settings.
I would suggest to perform a few tests to see what you get. |
January 14, 2020, 08:40 |
Raditya Wiranegara
Rep Power: 17 |
Ah yes, many thanks for pointing that out!
[ICEM] Wing body tutorial with tetra + prism | Far | ANSYS Meshing & Geometry | 5 | March 1, 2013 12:53 |
[ANSYS Meshing] ICEM Prism Meshing | fergal | ANSYS Meshing & Geometry | 0 | April 12, 2012 17:45 |
[ICEM] Prism meshing | itsayapan | ANSYS Meshing & Geometry | 2 | May 28, 2010 05:52 |
difference between Meshing Parameters | Mihail | CFX | 1 | April 29, 2008 04:44 |
Prism meshing in ICEM 11.0.1 | carno | FLUENT | 0 | April 1, 2008 08:24 |
