[ICEM] Blocking strategy for multi-element airfoil |
December 18, 2019, 10:45 |
Siddharth
Rep Power: 9 |
Hi everyone,
I am trying to create a structured mesh for double-element airfoil using ICEM CFD. Luckily, my first attempt was successful (PFA, the figures). The minimum angle and determinant were 36 deg and 0.9, respectively. But, I wish to know if there is a better way to do the blocking. Please share if anyone in the forum has any info regarding or past experiences. Let me know if you want to see the blocking and geometry files. Thanks in advance. |
December 20, 2019, 02:41 |
Please suggest something!
Siddharth
Rep Power: 9 |
Guys, any thoughts on the above?
Please let me know. |
December 22, 2019, 22:13 |
Thank you!
Siddharth
Rep Power: 9 |
Hi Shereez,
Thanks for the reply. Yes, the main element and the flap has a sharp trailing edge. Below is how I created the blocks. 1)Created a C-grid imagining, there is no gap between the airfoils 2)Then did the necessary splits and adjusted the vertices Could you please tell me how the blocking is done in your case? If it gives better quality, I will go with it. |
December 23, 2019, 05:29 |
#5 | |
The main block is split close to the flap (vertically). The flap block and the main block initially goes all the way back to the outlet, The blocks that goes to outlet (one from the flap and one from the main wing) are then collapsed using collapse blocks facility in ICEM. Then the blocks inside the flaps and wings are selected in two separate steps (or you can choose both at once) to create an O grid outside. After that its just linking the edges and linear splits, control points , mesh spacings etc to improve quality. Ps: https://www.youtube.com/watch?v=rfMn...YtBS-&index=12 I have explained in this video slat, wing, flap blocking if you will be interested. Blocking is a piece of art, there is no wrong way of doing it (if you know what you are doing ) |
December 23, 2019, 09:10 |
#6 | |
Siddharth
Rep Power: 9 |
Good that you have created a video earlier. I will update the thread as soon as I try the method. |
airfoil 2d, blocking strategy, multi-element, quality metrics |
Identifying Markers in a CGNS Mesh | tjim | SU2 | 3 | October 12, 2018 02:21 |
[ANSYS Meshing] Blocking and Meshing Strategy for an open flow domain over backward facing ramp | Crank-Shaft | ANSYS Meshing & Geometry | 0 | January 11, 2013 06:48 |
[ICEM] Blocking Strategy for Intersecting Tapered Cylinders | scribby182 | ANSYS Meshing & Geometry | 2 | December 17, 2012 11:02 |
[ICEM] Blocking strategy | BrolY | ANSYS Meshing & Geometry | 0 | July 22, 2010 05:46 |
Multi Element Airfoil | J.Dumas | Main CFD Forum | 2 | May 13, 2000 08:24 |
