[DesignModeler] I want to extend the line to cylinder...
Old   December 18, 2019, 03:38
Post I want to extend the line to cylinder...
M29
Sumin Park
M29 is on a distinguished road
Hello
I'm making some fins attached cylinder.
But there is a gap between line and circle in sketch.
actually i used the function of trim, extend and so on in the modify tab.
however the gap doesn't disappear.
I want to extend the line to circle in DM. What should i do???
please help me..
First image is whole sketch that i want to make.
Second image is fin.
Last image is the gap between fin and circle...
M29 is offline   Reply With Quote
Old   December 18, 2019, 22:33
RAJDEEP JAGDALE
RAJDEEP is on a distinguished road
The use of Coincident option under constraint tab in Design Modeler will help in solving this problem.
Regards,
RAJDEEP
RAJDEEP is offline   Reply With Quote
Old   January 7, 2020, 21:44
M29
Sumin Park
Regards,
RAJDEEP
Sorry I'm late
Thank you !! but it cannot work well. So i use "slice" and divide that.
ansys, design modeler, sketch
oscillating cylinder dynamic mesh Scabbard OpenFOAM Pre-Processing 160 September 2, 2024 10:53
[Gmsh] No cells read from file ".msh" hwsv07 OpenFOAM Meshing & Mesh Conversion 5 August 13, 2018 16:42
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 12:37
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
Problems of Duns Codes! Martin J Main CFD Forum 8 August 15, 2003 00:19
