December 13, 2019, 11:40 |
y* and surface roughness
André
Rep Power: 10 |
Hi everyone!
I have a couple of questions regarding y*/y+ and best practices for meshing and wall functions: 1. If we assume the same free stream velocity, what is the relation between y*/y+ and surface roughness? I assume a bigger surface roughness would yield higher shear stress, so y+ would be higher for higher surface roughness. Is this correct? Does this also maintain for y* (based on kinetic energy) ? In the case of using wall functions, shall we still aim for the guideline of y* in the range of 30 to 300? 2. If I use Fluent's Poly mesh with prism cells on walls, How can I allow for an adequate boundary layer cell size and adequate y* while still having a reasonable cell count and avoid huge growth factors and changes between the prism and poly cells? Thanks in advance guys!
Sapere aude! |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[ANSYS Meshing] generation mesh for simulation surface roughness in fluent | kamyarmech | ANSYS Meshing & Geometry | 2 | February 29, 2016 13:09 |
simulation of effect surface roughness on aifoil | kamyarmech | FLUENT | 1 | February 28, 2016 09:33 |
Surface Roughness | Magnus123456 | FLUENT | 0 | January 22, 2014 10:32 |
Surface Roughness Laminar Flow | cmh | OpenFOAM Pre-Processing | 0 | July 10, 2013 07:19 |
