[ANSYS Meshing] Inflation generation failed in a conjugate model |
November 19, 2019, 05:28 |
I am using ANSYS to simulate conjugate heat transfer conditions. Before starting on the real heat exchanger, I create a simple 3D model as a demo to practise meshing. This 3D model contains 3 parts, the outer zone represents cold fluid which has 1 inlet and 1 outlet; The inner zone represents hot fluid which need to be cooled by cold flow; And between them is a U shaped metal pipe, conducting heat from the hot side to the cold side. Here's the problem I encountered, as shown in the picture, I wanted to create inflation boundaries on both fluid zone surfaces, but however I assigned the Inflation control, there is no prisms on the cold fluid-pipe interface of the cold fluid zone. As mentioned, I am modeling conjugate heat transfer, so I turn on the assembly meshing option even though I didn't know if it was related. Would anyone help me solve this problem? It might be a simple issue but I do not know what to do, thanks a lot! |
November 19, 2019, 05:37 |
Another 2 pictures of my case.
meshing |
[Workbench] "Update failed for the Model component in Static Structural [...]" | So_ ANS | ANSYS Meshing & Geometry | 0 | February 10, 2016 13:00 |
Update failed for the mesh component in model | Kimican | Main CFD Forum | 2 | January 15, 2016 19:52 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Problems installing OpenFOAM 2.3.0, 1.6-ext and foam-extend 3.0 | sam.ho | OpenFOAM Installation | 35 | April 5, 2014 16:31 |
