[ANSYS Meshing] Meshing error - geometry independent |
October 7, 2019, 05:38 |
Mads Holm
Rep Power: 7 |
I get the following error when trying to create a simple mesh. "A software execution error occurred inside the mesher" "an inter-process communication error occurred while communicating with the MESHER" I have tried to make a very simple geometry (1x1x1m square) and I still get the same mesher. I am using ANSYS 19.2 - I get the same error in 19 R3. and running on a 'ANSYS Academic research Mechanical and CFD' license Does anyone have a suggestion to how I can resolve this issue? Thanks in advance |
October 10, 2019, 12:32 |
Erik
Rep Power: 23 |
Probably a corrupted workbench file. Start a new fresh new one and see if it works.
October 16, 2019, 06:42 |
Mads Holm
Rep Power: 7 |
Hi, this doesn't help, I still see the problem. I have tried to start a new project, draw a new geometri I designmodeller, and the meshing error still occurs.
I have tried this in both ANSYS 19.2 and 19 R3 - without any luck |
October 16, 2019, 14:12 |
Erik
Rep Power: 23 |
Try uninstalling and reinstalling the program? There is no reason it shouldn't just not work on something simple.
But you said you get the same thing with both versions, so I have no idea why it would not work correctly. You are just using workbench "analysis systems" Fluent or CFX on the Project page? What if you try to do a static structural analysis, will that mesh? |
mesher |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 11:49 |
[ANSYS Meshing] Icem meshing queries | Mfaizan | ANSYS Meshing & Geometry | 21 | July 31, 2015 00:10 |
[ANSYS Meshing] Cooper Method Meshing | RTN3000 | ANSYS Meshing & Geometry | 1 | March 2, 2015 00:59 |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 06:22 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 12:08 |
