[ANSYS Meshing] Ansys Meshing taking forever for Prism Layer
Old   October 5, 2019, 07:34
Default Ansys Meshing taking forever for Prism Layer
torreh is on a distinguished road
So I am trying to mesh a fairly complex car Geometry in a windtunnel for external aerodynamics. when I first tried to mesh without prism layer it worked fine and was done in about 5 to 10 minutes. Now I changed nothing but assigned mutiple components to have Prism Layer and now it takes forever (1 hour and it still has not finished). It also does not show any process either.
so I do not know wether it is actually working or if it has hung up.
The Prism layer is defined by the thickness of the first layer. Which might also play into the problem because when I generate it with the thickness of the whole Boundary Layer given, it works a lot quicker.
to be fair the geometry is very complex and I have a very thin first layer (about 0.03915mm). I am looking to generate 14 layers with exponential growth rate.
I do not see why it would be taking so long. I have a really strong pc with 32gb Ram (which is not nearly maxed out during meshing) and 16 cores
torreh is offline   Reply With Quote
mesh, prism, prism layer, taking long
[ANSYS Meshing] Ansys meshing does not respond when it is opened after the first time MikhO ANSYS Meshing & Geometry 0 February 16, 2018 09:08
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
[ICEM] 2d Aerofoil meshing in ansys ICEM syler3321 ANSYS Meshing & Geometry 2 February 3, 2012 02:59
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 06:22
[ANSYS Meshing] Ansys meshing with extended meshing jsm ANSYS Meshing & Geometry 6 January 10, 2011 13:09
