September 12, 2019, 11:11 |
Failed Mesh
Hello guys!
I am trying to simulate the flow over an uav with tail wing for my final year project.When i try to mesh it with default settings, it gives a failed mesh with the following messages: 1.Mesh can not be generated with the current settings.Try reducing the size. 2.Meshing failed on one or more faces. If i reduce the minimum size of the elements, a mesh is generated successfully but it takes almost 40 minutes and has about 50 lakh elements.I cant run the simulation with so many elements as i dont have a high end processor and no. of test cases is also high. What should i do to generate a mesh with less number of elements? Thanks in advance! |
September 12, 2019, 11:41 |
zohair
Rep Power: 13 |
Check with surface. There could be some complex area where the mesh is penetrating.
I believe the reduction in size is solving that problem, but bigger element size is giving a failed message. |
September 21, 2019, 02:47 |
#3 | |
And it takes almost an hour to generate the mesh. |
September 25, 2019, 15:00 |
Have a nice time!
Rep Power: 11 |
Hello, you can make a special size for only the area needs the small size. By selecting that body or that particular face and set a small value for the cell size. The issue is generated from the fact that the body is complex and the big values give a high skewness value. You should overcome this by any way.
Danke! |
failed mesh |
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 04:35 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
