[ICEM] How would you block a wing-tip tank like this? |
Rep Power: 7 ![]() |
I'm having troubles in meshing a wing with a wing-tip tank. I tried blocking as you can see in the picture, I get no errors in mesh checking, but there is a strange behaviour of the mesh on the tank. Can someone help me? These are the links of the images Last edited by micdg96; September 22, 2019 at 06:17. |
Sebastian Engel
Rep Power: 21 ![]() |
Hi micdg96,
it seems you are not yet finished with blocking. You blocking does not respect the curvature on the tip of the tank. You might need a local c-grid there. Right now there seems to be one face which has to cover half a sphere. If the picture at the tail is also an issue (i cant really see, the resolution is too coarse), then you need to check, whether you don't degenerate a block in that area (such as merged vertices/edges). Do you know about the guide Simons Tips and Tricks (read the stick post of this subforum)? It might give you a bit more insight, why you get the current mesh from your blocking. Best regards, Sebastian |
Thank you Sebastian. Doing a Local C-Grid around the spheric surface solved my problem!
ansys, icem, mesh 3d, wing, wing tip |
[DesignModeler] Meshing a Delta Wing ANSYS CFX - Cannot get inflation around the tip of the wing? | Jack121 | ANSYS Meshing & Geometry | 0 | April 12, 2019 10:08 |
[Commercial meshers] Error in converting mesh from cfx4tofoam Can you please help me?! | losiola | OpenFOAM Meshing & Mesh Conversion | 1 | January 8, 2019 22:01 |
[ICEM] O-grid around wing geometry | Anorky | ANSYS Meshing & Geometry | 15 | November 27, 2017 13:43 |
Solver for simulating wing tip vortex | teodm | OpenFOAM Running, Solving & CFD | 0 | December 8, 2016 18:19 |
[ICEM] How to block this? | cfd seeker | ANSYS Meshing & Geometry | 24 | November 22, 2012 09:33 |
