[TGrid] multiple faces selection via scripting (ex. for BL creation or remeshing)
Old   August 30, 2019, 05:12
Default multiple faces selection via scripting (ex. for BL creation or remeshing)
Fabio Malizia
Fabio88 is on a distinguished road
Do you know how to apply a scoped size function to several faces without using the wildcard * ? For example, I want to use the same boundary layer for a wheel and the ground. Now I use two code lines:
/mesh/scoped-prisms/create bl-example1 last-ratio 1 5 40 fluid fluid-regions selected-face-zones ground
/mesh/scoped-prisms/create bl-example2 last-ratio 1 5 40 fluid fluid-regions selected-face-zones wheel
Is it possible to group ground and wheel in one, so that I can use only one line?
i have the same issue with remeshing selected faces.
Thanks for any suggestion you can provide me.
Fabio88 is offline   Reply With Quote
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 09:26
[snappyHexMesh] Layers not growing at all zonda OpenFOAM Meshing & Mesh Conversion 12 June 6, 2020 12:28
[snappyHexMesh] SHM is not extruding/adding Layers everywhere matthiasd OpenFOAM Meshing & Mesh Conversion 2 October 16, 2016 17:45
decomposePar -allRegions stru OpenFOAM Pre-Processing 2 August 25, 2015 04:58
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 09:14
