[ICEM] Dimension Problem Between Geometry, ICEM and Fluent |
Oguzhan Gokkaya
Rep Power: 0 ![]() |
Hi everyone,
I am workıng on an internal pipe flow problem so i generate my geometry in Design Modeler and then send it to ICEM to observe flow better. After i give node numbers and ratios, convert it to unstructured mesh. Finally, send ICEM mesh to Fluent solver but dimensions doesn't match with one that i decided in Design modeler. Also, i realized some differences in ICEM too. Diameter in Design Modeler: 0.5 mm Diameter in ICEM : 0.500000002374872 mm Diameter in Fluent : 0.4995726 mm Do you know where this mismatch comes from? ![]() ![]() ![]() ![]() ![]() Last edited by gokkayaoguzhan; August 29, 2019 at 03:07. |
Oguzhan Gokkaya
Being exact is very important for this geometry. I scaled dimensions in Fluent but i am suspicious about any remaining fractions or disruption in the mesh caused by this scaling function.
gokkayaoguzhan |
dimensions, icem 3d |
ICEM to Fluent (2D Geometry): File has wrong dimensions? | mullzer | FLUENT | 2 | December 24, 2021 01:02 |
FLUENT adding mesh nodes problem when importing 3D mesh from ICEM | guxin7005 | FLUENT | 2 | June 27, 2016 21:41 |
[ICEM] Meshing adjacent wall geometry and simple ICEM questions | everdimension | ANSYS Meshing & Geometry | 25 | June 20, 2012 04:25 |
Dimension conflict between icem cfd and fluent | highhopes | ANSYS Meshing & Geometry | 1 | September 9, 2011 11:07 |
[ICEM] [FLUENT] 2D Geometry problem when exporting to Fluent - Unwanted walls | MikeTichondrius | ANSYS Meshing & Geometry | 1 | February 9, 2011 13:31 |
