August 20, 2019, 20:10 |
help curvature mesh
Sebastian
Rep Power: 7 |
Hello everyone, I would like to ask you for advice and help to mesh the following pipe, it is based on the
1+ 0.1sen (2 * pi * x) function and I need to have the highest precision and refinement in the curved wall of the figure and that on the Z axis the figure has only 1 cell. having the student version I cannot exceed 512k nodes. |
August 20, 2019, 20:11 |
#2 | |
Sebastian
Rep Power: 7 |
August 21, 2019, 04:08 |
Gwenael H.
Rep Power: 20 |
Hi Sebastian,
If I get it right you want to solve a 2.5D problem (using a one cell in the Z direction). If you want to focus mainly on the upper curved part of the geometry I would suggest to split the geometry with similar function (smaller amplitude and vertical offset) to end up with 2 sub-surfaces. Then in Ansys meshing you can simply add a Face mesh on the upper part with biais edge sizing. Have fun |
cfx, curvature, fluid, meshing |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 08:34 |
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) | shubham jain | ANSYS Meshing & Geometry | 1 | April 10, 2017 06:03 |
[snappyHexMesh] Snappyhex mesh: poor inlet mesh | Swagga5aur | OpenFOAM Meshing & Mesh Conversion | 1 | December 3, 2016 17:59 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
