ICEM meshing problem - degenerated block problem
Old   August 9, 2019, 13:33
Default ICEM meshing problem - degenerated block problem
Malte
stud-many is on a distinguished road
Hey there. This is kind of urgent.
I'm trying to simulate a radial compressor with a cavity-flow behind the rotor-blisk. therefore i imported the rotor-blocking from turbogrid, made a 2d-blocking of the cavity, transformed this into a 3d-blocking and then i tried to merge those meshes.
somewhen i oviously made a mistake and i just would like to fix this. i merged 2 verticies that should not have been merged (as seen in the picture)
the split-vertex function does not work ("unusual neighborhood"). Does anybody have an idea how to solve this issue?
thanks in advance.
EDIT / SOLVED: i now deleted the blocks and created new ones by hand.
stud-many is offline   Reply With Quote
Old   August 12, 2019, 12:04
Alexander
Pospelov is on a distinguished road
thanks in advance.
Hello.
Delete this 4 blocks, and create new one.
Alexander.
Pospelov is offline   Reply With Quote
icem, merging, split, vertex
[ICEM] Icem meshing problem in T junction geometry Abdullahkhan0070 ANSYS Meshing & Geometry 2 November 27, 2017 12:16
[ANSYS Meshing] Meshing problem using ICEM CFD cgpa4 ANSYS Meshing & Geometry 2 November 4, 2012 13:22
[ICEM] ICEM Meshing problem nitinbansal184 ANSYS Meshing & Geometry 3 August 22, 2012 03:19
[ICEM] Meshing problem from ICEM CFD to Fluent cfdonlinederafa ANSYS Meshing & Geometry 2 September 21, 2010 17:16
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 03:58
