[DesignModeler] How to design the geometry of a Subsea Jumper using Ansys.
Old   August 1, 2019, 10:04
Question How to design the geometry of a Subsea Jumper using Ansys.
Faro Ayodeji
Faro is on a distinguished road
I am trying to recreate the attached image on Ansys, although I have been able to develop this sketches but the application of sweep keep telling me "sweep path must contain exactly one chain ansys".
How do I go about this? Your suggestions would be well appreciated.
Faro is offline   Reply With Quote
Old   August 12, 2019, 09:10
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Hi Faro,
According to your sketch you didn't add the horizontal lines, hence you'll end up with several "sub" lines in one sketch which cannot be used for the sweep path.
If you correct those you should be fine.
Have fun
Gweher is offline   Reply With Quote
Old   August 13, 2019, 12:27
MIDHUN
MIDHUN@CFD is on a distinguished road
Send a message via Skype™ to MIDHUN@CFD
make the bend radius little more higher and try
MIDHUN@CFD is offline   Reply With Quote
Old   August 14, 2019, 03:20
Gweher's Avatar
Gwenael H.
The bend radius is not the problem here as the extruded profile is not self intersecting at the different bends.
ansys, design, design modeller, spool.
Error Running Design of Experiments in ANSYS Fluent tytrzecki FLUENT 0 April 22, 2018 16:01
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 06:52
ANSYS: Design of Experiments and Optimization - Upper and Lower Bounds mrswordf1sh ANSYS 0 April 5, 2018 08:33
Issues Importing Geometry (Hyperloop Design) iiwolf ANSYS 1 December 2, 2015 19:25
2-way FSI in Ansys CFX 15 LucasGasparino CFX 3 August 6, 2015 04:17
