[ICEM] How to change blocking around the mesh with change in design parameters?
Old   June 11, 2019, 17:39
Default How to change blocking around the mesh with change in design parameters?
Anup Jain
jainanup27 is on a distinguished road
I am trying to run a optimization problem. My optimization flow is
Design Modeler --> ICEM CFD --> Fluent --> Design Exploration.
When I change the parameters in the Design Exploration the Geometry changes. With this change in geometry the mesh created in ICEM CFD also changes . However, it seems that the blocking created during the first iteration remains the sane. As result when I change the geometric parameters, due the same blocking and changed mesh I have overlapping edges.
Can anyone tell how to change the blocking with the change in Geometry.
Or is there some other way that I cam create mesh around the geometry without creating blocking and for the rest of the domain I have blocking.
I have attached the snapshot. Image 1 is the geometry. Image 2 is the blocking and image is 3 is if we can do something like this.
Thanks,
jainanup27 is offline   Reply With Quote
design explorer, fluent, icem 2d blocking
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 05:17
Mesh Morpher -Deformation, How to change Parameters Values through UDF? alasz FLUENT 0 December 21, 2018 11:01
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
Mesh sensitivity when using phase change models BKaus STAR-CCM+ 0 February 28, 2012 21:51
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
