[ANSYS Meshing] Problem in convergence due to poor mesh quality |
June 11, 2019, 01:48 |
Abhishek Dahiya
I am trying to simulate a ceiling fan using the sliding mesh technique. The fan is of 24-inch dia, a cylindrical rotating domain encloses the fan and enclosure(room) is 10*10*9 feet. I have tried many meshing techniques. Most of them give an error "mesh could not be generated with given input". meshing was successful using patch conforming tetrahedral but the minimum orthogonal quality is of the order of 10^-9 and maximum aspect ratio of 10^3. I am sure this is the reason for divergence error.
I have tried all the resolution of mesh and different element size, from total elements value of around 900000( min element size - 200 mm) to around 30000000 ( with min element size of 10 mm and 2 refinements at blades of fan in the rotational domain). there is a little change in the numbers of orthogonal quality and aspect ratio. The geometry is pretty smooth and simple. don't think there should be any problem because of that. Please Help! |
June 14, 2019, 21:01 |
jey
Rep Power: 10 |
Hi dahiya3806,
Can you please post a picture of your geometry just to get an idea? Best, Ioannis |
June 15, 2019, 00:53 |
Abhishek Dahiya
I am able to get the orthogonal quality up to 0.015 by removing bolts and holes but that's still not good enough. The case diverged after 350 iterations (11-time steps of 0.001 sec). Should I go for an even smaller time step? No. of elements in mesh - around 2,600,000. Rotating domain velocity - 350 RPM. I am using the K-E turbulence model. |
aspect ratio, divergence amg solver, orthogonal quality, sliding mesh method |
[ANSYS Meshing] Problem with Inflation Descreasing Mesh Quality | wildan | ANSYS Meshing & Geometry | 20 | March 4, 2019 04:29 |
mesh quality problem for displacementSBRStress motion solver | zhaozhenkai | OpenFOAM | 0 | January 22, 2017 12:02 |
increasing mesh quality is leading to poor convergence | tippo | CFX | 2 | May 5, 2009 11:55 |
CONVERGENCE PROBLEM - oil boiler | MM | FLUENT | 1 | February 15, 2007 06:24 |
convergence problem with SIMPLER | NURAY KAYAKOL | Main CFD Forum | 1 | February 24, 1999 14:43 |
