June 8, 2019, 06:53 |
ICEM Unstructured Mesh Body Problem
ozan
Hi all,
I am new in ICEM and trying to model aircraft with propeller. In order to do that I choose sliding mesh and am trying to create unstructured mesh since blocking will be cost too much time. First, I tried to create meshes for propeller and its boundary separately. But when create volume mesh, it creates volume meshes inside the propeller even I have created body for fluid. My curves are red and I could not find the problem. Could you help me? I am adding link and some pictures of project below. https://drive.google.com/file/d/1mbr...ew?usp=sharing Thank you so much Last edited by bjkozn; June 9, 2019 at 10:08. |
June 10, 2019, 07:55 |
Stuart
Rep Power: 26 |
You are using the Octree volume mesh method. Put an OFRN material point inside the propeller. I assume you have a LIVE material point in the fluid where you want the mesh. See if that helps
June 11, 2019, 05:13 |
Gert-Jan
Rep Power: 28 |
Maybe a stupid question, but where are your surfaces? Can you show these?
They are more important than curves. Probably your propellor is not closed |
aircraft design, icem 19.0 |
[ICEM] The ICEM Guide for CFX Users | JuPa | ANSYS Meshing & Geometry | 11 | September 4, 2017 10:43 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
Unstructured Mesh ICEM on a cube | jerome_ | ANSYS | 0 | May 30, 2012 06:34 |
problem when converting mesh (made by ICEM) using fluentMeshToFoam | Forrest_Lei | OpenFOAM | 11 | October 16, 2009 07:28 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 11:09 |
