[ANSYS Meshing] Poor mesh metrics using inflation on wall of helical pipe |
Rep Power: 7 ![]() |
I'm fairly inexperienced with meshing and hope this is a trivial problem! I have a helical pipe model which needs to be simulated with a K-w SST turbulence model for a study. For this model I need to reduce my first layer height of the mesh to y+<1. However when I try to assign any kind of inflation layer on the wall my uniform grid turns in to unstructured tetrahedral and wedge elements and I get really poor mesh metrics. My first layer height needs to be in the region of 2.5x10-4 mm. The pipe has a height of 40mm, diameter of 1mm, coil diameter of 6.6mm and pitch of 20mm. I've attached an example to show how the mesh changes, even with a large first layer I still get this issue. |
Stuart
Rep Power: 26 ![]() |
Try the MultiZone with inflation layer for the wall capture and adjust the inflation details to suit your simulation. Use a Face Meshing for the O-grid.
Thanks that looks great! are you able to send the settings you used for each of the features? just as a basis so i can modify for my own wall requirements
Stuart
I did not apply any settings to the MultiZone or Face Meshing. I set a global element size. I set Smooth Transition in the Inflation Layer and 10 layers. That is all.
Hi Stuart, sorry for the delayed reply. It worked really nicely thanks for the help!
boundary layer, helix, inflation, mesh metrics, pipe flow |
Divergence in AMG solver! | marina | FLUENT | 20 | August 1, 2020 11:30 |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
