[ANSYS Meshing] Associations Problem
Old   May 7, 2019, 11:53
Default Associations Problem
Dimitrios Chantzaras
Dim_Cha is on a distinguished road
Hallo to the community,
I want to aks for a problem a have. I am doing my Master Thesis and I have to mesh a SpraySyn standardized burner. After spliting the Blocks, editing the Associations and generating the Pre Mesh with No Projection everything is fine.
When I recompute the Pre - Mesh with projection to the Edges I have a disformations of the Cells. So my Mesh quality is confoundedly low. But the Asscociations looks optically correct.
Is anybody who can give a reason what could be the problem? For easiness I upload a picture with the problematic zone.
Thank you very much
Dim_Cha is offline   Reply With Quote
Old   May 8, 2019, 03:14
M
AtoHM is on a distinguished road
Hm, I dont think the big white arrow association of the central low point is correct. Delete it and recompute the pre-mesh, I assume this will fix it.
The edges are correctly associated its just that vertex.
AtoHM is offline   Reply With Quote
Old   May 8, 2019, 11:50
Yes, I know thats the Problem. I tried to fix the association but its not possible.
Old   May 9, 2019, 03:02
M
How did you try to "fix" it?
Within the association menu there is an option to delete associations (its a yellow hand/finger with a red cross in the symbol). There you can choose to delete vertex/edge/face associations. Use the delete vertex association tool, select that vertex and hit mouse wheel to perform the action. This should remove the association (and the white arrow with it). Then rebuild the pre-mesh.
Old   May 10, 2019, 06:02
Ok. I found the Problem. The surface was missing. Thanx
associations, help in mesh, mesh, problem, student
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
