[ICEM] Conjugate Heat Transfer - Conformal Mesh
Old   March 30, 2019, 20:03
Default Conjugate Heat Transfer - Conformal Mesh
Ramaswamy Devakottai
rsdevako is on a distinguished road
Hello all,
I would like to learn on how to create a conformal mesh in ICEM CFD for Conjugate Heat transfer applications.
I have a modest experience in meshing in ICEM CFD for a single part bodies - domains containing only fluids.
I am working on a course project and it would be really great if someone could tell me the way to go about in learning CHT structured meshing in ICEM.
Thanks.
rsdevako is offline   Reply With Quote
Old   April 1, 2019, 11:26
Sebastian Engel
bluebase will become famous soon enough
Hi Ramaswamy,
do you have access to the tutorials of ICEM? This would be a good way to start learning how to do this.
Best regards,
Sebastian
bluebase is offline   Reply With Quote
Old   April 1, 2019, 12:19
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Originally Posted by rsdevako View Post
Hello all,
Thanks.
You will create confomral meshes for multiple fluids in same way as you do for single fluid.
But as per Fluent recommendation it is better to use interfaces between solid and fluid. As we dont need much fine mesh in solid part. Please go through those parts of user guide or tutorial in Fluent documentation
Far is offline   Reply With Quote
Thermal non-equilibrium porous media model with conjugate heat transfer Hexahedron FLUENT 9 February 22, 2023 03:55
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
[ANSYS Meshing] Fluent Conjugate heat transfer: Temperature at a small fluid region exceed limit RPjack ANSYS Meshing & Geometry 1 June 20, 2019 08:11
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 03:54
