February 21, 2019, 07:44 |
2D Mesh for Sandia Flame D
S Li
Rep Power: 7 |
I am a beginner in combustion modeling. I woud like to practice modeling the Sandia Flame D using OpenFoam as a starting point. But I don't know how to generate the geometry/mesh. Can anyone advise me where to find a meshing file to download? Or advise me how to generate such a mesh? Thank you very much! |
February 21, 2019, 09:35 |
M
Rep Power: 13 |
first of all, this is the ANSYS forum. You mentioned to use OpenFoam which has its own meshing tools as well. I didnt know what Sandia Flame was in the first place so I googled and found this: https://www.youtube.com/watch?v=lSZXAcrX1YQ Is that what you try to do? The geometry for it seems to be quite simple. Do you have a CAD program at hand? Could be done in DesignModeler (ANSYS) or something like FreeCad and then mesh it using cfmesh? I recommend doing the mesh yourself instead of using someone elses. Meshing is a basic part of CFD studies. |
February 21, 2019, 22:43 |
S Li
Rep Power: 7 |
Hi, AtoHM,
Thank you for the info. Yes, the burner geometry is fairly simple. Based on your info, I think I can use Solidworks for drawing the geometry. Then I can mesh it using meshing tools like cfmesh. |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
[ICEM] Problem making structured mesh on a surface | froztbear | ANSYS Meshing & Geometry | 4 | November 10, 2011 09:52 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 09:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
