[DesignModeler] Create body from faces
Old   February 17, 2019, 16:52
Default Create body from faces
egge24 is on a distinguished road
Hi all,
I'm having some difficulties trying to create a body made of 4 faces. The boy represents an open channel so the material will be "fluid".
The four faces (see attached Figure) are:
  • A wall: consists of an imported .stl file that represents the bottom of a navigational channel.
  • An inlet: a surface created from points and edges in design modeller.
  • An outlet: a surface created from points and edges in design modeller.
  • A symmetry: a surface created from points and edges in design modeller.
How can I merge all 4 surfaces to create a body?
Thank you.
Kind regards,
Edu
egge24 is offline   Reply With Quote
body building, geometry fluent
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 15:49
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
