[ICEM] Mirror 2D planar mesh
Old   February 14, 2019, 05:23
Default Mirror 2D planar mesh
Edee O'Hare
Edee is on a distinguished road
Hi, I have rather simple 2D planar mesh which I would like to mirror to get symmetrical mesh. However, if I use Edit mesh/Transfor mesh/Mirror and check copy, merge nodes and delete duplicate elements in the menu, the resulting mesh can't be exported to Fluent giving error: Child killed - segmentation violation. It happens also if I check the mesh using Check mesh tool and delete all duplicate elements.
I thought it would be a peace of cake but now I struggle with this for two days without any result
Thank you for any suggestions or description how to do that!
E.
Edee is offline   Reply With Quote
Old   February 14, 2019, 10:56
Edee O'Hare
Ok, I made the simplified geometry and identified the problem, however, I have not solved it yet. The problem is that I use the mesh refinement on the blocks which are neighbouring the mirror axis (see attached pictures). That produce non-manifold vertices which the automatic repair can not fix...
mirrormesh, planar, symmetric mesh
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) shubham jain ANSYS Meshing & Geometry 1 April 10, 2017 06:03
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
