[ANSYS Meshing] Parallel meshing utilisation failing |
February 14, 2019, 03:42 |
Chris C
Hi all, I am trying utilise as much CPU/computational power to perform mesh generation on my PC as possible (I do not need to use the computer for anything other than meshing). I have seen tutorials online (e.g. https://www.youtube.com/watch?v=VDc_KGFKcrU) how to do this but does not seem to affect CPU performance or change mesh times. Settings used:
PC used: See images * I performed two tests, see below: Test 1: number of CPU’s for meshing method = 0 number of CPU’s for parallel part meshing = programme controlled CPU utilisation ~ 30% (estimated) Meshing time = 4m 20s Test 2: number of CPU’s for meshing method = 4 number of CPU’s for parallel part meshing = 4 CPU utilisation ~ 33% (estimated) Meshing time = 4m 23s See images for PC performance during the two tests meshing processes. How can I utilise all possible computational resources to reduce meshing times? I am happy to use any and all resources the PC has (all 8 CPU's) and will not use the computer for anything other than meshing. Any and all help and advice will be very warmly received. Many thanks. Regards, Christopher |
cpu usage, meshing 2d, meshing and geometry, parallel, parallel meshing |
[snappyHexMesh] snappyHexMesh - 3D Wing Meshing Setup & Trials | denbjornen | OpenFOAM Meshing & Mesh Conversion | 1 | May 25, 2020 12:14 |
[ANSYS Meshing] Meshing parallel | Andrea159357 | ANSYS Meshing & Geometry | 0 | January 3, 2019 19:36 |
[cfMesh] Parallel meshing in cfMesh v1.1.1 in windows | naveen.hariprasad | OpenFOAM Community Contributions | 0 | December 16, 2016 04:24 |
[ANSYS Meshing] Meshing small air gap between parallel disks | AlexRonto | ANSYS Meshing & Geometry | 1 | November 4, 2016 09:02 |
[ANSYS Meshing] Meshing in parallel | oborona | ANSYS Meshing & Geometry | 24 | October 15, 2015 11:54 |
