[ANSYS Meshing] Meshing progress box does not appear
Old   February 11, 2019, 14:53
Default Meshing progress box does not appear
trooken is on a distinguished road
When generating my mesh within ANSYS Meshing, the box that usually appears showing the progress of the meshing, with the option to stop, no longer appears on the screen. The mesh still generates, however the lack of seeing the progress is not ideal at all.
trooken is offline   Reply With Quote
Old   February 12, 2019, 05:19
Baris PULAT
bpulat is on a distinguished road
Try to do these operations :
1- Open Windows Run function
2- Type %appdata% there
3- Go to Roaming then Ansys folder
4- Select your version of Ansys that you are using
5- There is a file name UserRegFiles_somenumber
6- Inside there is SOFTWARE.xml
7- Search ProgressWindowCoordinates inside of the .xml file
You should find some thing like this :
<VALUE ObjectName="ProgressWindowCoordinates" Value="244,320,646,494" ValueType="2"/>
Check your coordinates in there. In mine written as "244,320,646,494"
If there is a negative value make it positive.
bpulat is offline   Reply With Quote
Old   May 26, 2019, 00:07
Charles
atrament is on a distinguished road
I am having the same issue. Did you happen to resolve this?
atrament is offline   Reply With Quote
[ANSYS Meshing] Cant get parallel meshing to work in V18.2 jones007 ANSYS Meshing & Geometry 17 November 9, 2020 06:56
[snappyHexMesh] snappyHexMesh - 3D Wing Meshing Setup & Trials denbjornen OpenFOAM Meshing & Mesh Conversion 1 May 25, 2020 12:14
[ANSYS Meshing] 2D Meshing of Parallel Airfoils Fco.Herbert ANSYS Meshing & Geometry 1 December 5, 2017 16:42
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 02:09
Immersol Simulation of a Heated Box Dong Phoenics 0 March 2, 2006 22:20
