[ICEM] parts in ICEM are missing after importing to fluent |
January 26, 2019, 14:48 |
Weiqiang Liu
Rep Power: 9 |
hello, all
I am trying to mesh a straight channel with catalyst coated on the wall. For the numerical convenience, the leading edge of the wall has no catalyst, namely inert and it's called inert wall in my geometry. The other wall has catalyst on it and is called catalytic wall in my geometry. my problem is : After I import the generated mesh into fluent, the inert and catalytic parts are missing. Instead, a surface called geom emerges automatically to replace inert and catalytic wall. I can not figure out why this happens. Can anybody give me some suggestions? Thanks a lot Weiqiang. geometry.png partlist.png fluent boundary list.png |
January 27, 2019, 13:21 |
Sebastian Engel
Rep Power: 21 |
Do you have the necessary surfaces/lines in the right part?
And do you set a boundary condition for each part? Best regards, Sebastian |
January 28, 2019, 03:29 |
M
Rep Power: 12 |
Did you have a different geometry in ICEM before the current one?
If you build a project (blocking, mesh, whatever) on a geometry and then change it at some point (close geometry, import other model) you need to make sure that the old blocking is moved to belong to the new material point. If this is not done correctly, some of the old blocking and referencing may stay in the project. I saw the same behavior as you described when I made that mistake once. I see you still have an entity called Geom in your tree so I guess thats the issue. To resolve it, make a RMB-click on your current material point and "add to part". Then in the menu switch to "add blocking material". Make blocks visible if needed and assign all the blocking to the new material point. Make sure Geom is deleted after the new mesh is created. |
icem, parts are missing |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 10:07 |
[ICEM] Missing face critical error while importing icem mesh to fluent | tuhin | ANSYS Meshing & Geometry | 4 | March 12, 2018 09:20 |
[ICEM] missing interface between two zone while importing from ICEM to FLUENT | @nuj | ANSYS Meshing & Geometry | 0 | April 6, 2016 09:23 |
Importing 3D cylinderica shell to ICEM for meshing and FLUENT flow simulation | eidowu21 | Main CFD Forum | 0 | March 12, 2016 14:39 |
Transport mesh from ICEM CFD, to Fluent, to Sysnoise | Wieland | FLUENT | 2 | April 15, 2012 07:28 |
