[ICEM] Terrible Mesh in the middle slice
Old   January 2, 2019, 16:25
Default Terrible Mesh in the middle slice
Yaopeng Li
Eleven Leo is on a distinguished road
This is a 60deg mesh, and it looks fine from outside. However, when you make a slice in the middle of the mesh (i.e., 30 deg), the mesh is terrible, as you can seen. Other slices (e.g., 20, 25, etc) are all OK, only the middle slice is wrong. Anyone can help me find out the reason or possible reason?
Thank you very much for your kind help.
Best
The following are outside mesh and middle slice:
Eleven Leo is offline   Reply With Quote
Old   January 3, 2019, 18:16
Gert-Jan
Gert-Jan will become famous soon enough
I am not convinced this is a real error. It might be that it is just a matter of inaccuracies when slicing the mesh. Please check the mesh quality perpendicular to this plane: take a z-plane.
Gert-Jan is offline   Reply With Quote
Old   January 4, 2019, 19:48
Sebastian Engel
bluebase will become famous soon enough
Hi Yaopeng,
i agree with Gert-Jan. This is not an error but a property of a slice.
Instead of using a slice, you might should try the feature "Scan planes". It is hidden in the context menu of Premesh - in the model tree.
With this feature you can draw and select specific layers of your blocking.
Best regards,
Sebastian
bluebase is offline   Reply With Quote
icem, mesh
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh sc.park OpenFOAM Meshing & Mesh Conversion 1 March 13, 2016 14:28
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
